security light on w/ resistor use
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30185
Printed Date: March 19, 2026 at 11:57 AM
Topic: security light on w/ resistor use
Posted By: cargovan
Subject: security light on w/ resistor use
Date Posted: April 11, 2004 at 5:48 PM
i just did the remote start on the chevy express 04 and use resistor to bypass the passlock , and now the security light stay on when driving. please tell me if i use the bypass kit will take care of this and which kit to buy thanks
Posted By: desh187
Date Posted: April 11, 2004 at 6:58 PM
easiest thing to do is to disconnect those resistors and join any wires you might have cut.
disconnect the battery terminal for about 30 secs,will erase faulty codes.light will turn off.
Posted By: godsegoizhuge
Date Posted: April 11, 2004 at 8:16 PM
do like desh said. then after everything is fine go get yourself like the 555L or the plxr from bypasskits.com. both systems work great.
Posted By: cargovan
Date Posted: April 12, 2004 at 12:29 AM
thanks guys
Posted By: tjdurham
Date Posted: April 12, 2004 at 12:21 PM
or get a pldata (no cutting) it will work have done about 25 xpresses
------------- tj
Posted By: cargovan
Date Posted: April 12, 2004 at 11:52 PM
TODAY imade a copied key ,turned out it does start the van.I definately gonna need a bypass unit now. I asume ,with this unit ,the copied key will not do the "START" AM I RIGHT?
Posted By: JWorm
Date Posted: April 13, 2004 at 8:03 PM
There is nothing special about the ignition key in the Passlock II system. The system works off a resistance created in the key cylinder when it is turned by the key. VATS works off a resistor in the shaft of the key, while Passkey III systems work off a transponder in the head of the key.
You can use a relay and resistor to temporaily bypass Passlock II. How did you wire it, and how did you determine the resistor value?
