mercury sable door lock problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30282
Printed Date: March 18, 2026 at 3:08 AM
Topic: mercury sable door lock problem
Posted By: SNIPE22
Subject: mercury sable door lock problem
Date Posted: April 12, 2004 at 11:51 PM
Ok I have been trying to get the keyless part of the Galaxy5000rs2w  to work with a alot of help from Bmf1000  I haven't been succesful getting it to work I know i have to use the 5 wirer connection diagram but  it still doesn't lock/unlock the doors i know the wirers are
PNK / YELLOW  -----------LOCK------
PNK/LT GREEN ----------UNLOCK-----
But the strange thing I notice today was that when I cut the lock wirer and unlock wirer when I press switch to the lock position I tested it with the ohm meter and I saw that the end leading to the door was the switch part but when i try the other end that I cut on the same wirer and put the ohm meter to it I place the switch on the unlock position and it show that power was going to it so I am not sure what the heck is going on and I was checking the repair manual and in it I see that the pnk / YELLOW & pnk/lt green wirers go to the front passenger door switch and from there it goes to the lock motors of the car but after the pnk / YELLOW  & pnk/lt green wirers go through the front passenger door switch they turn into a different color into pnk/orange & pnk/black and they go straight to the drivers lock motor, so I am wondering what can I do since I try both the pnk/orange and pnk / YELLOW and still nothing another thing is that when i try the diagram here it blows the inline 30amp fuse but when I use the bulldogsecurity diagram the fuse doesn't blow at all but still doors don't work so if anyone can shed some light on this problem I will be extremely greatful.
Posted By: italnpimp59
Date Posted: April 13, 2004 at 1:10 PM
what year sable is it?  if its blownig fuses then u have your  relays wired up wrong.  it may not be a reverse polarity system.  all the newer ford/mercury cars are negative pulse.  so let us know what year it is
Posted By: SNIPE22
Date Posted: April 13, 2004 at 1:58 PM
I forgot is a 88 mercury sable 4 doors with power locks no keyless module that I know of
Posted By: derek123
Date Posted: April 13, 2004 at 3:30 PM
It should be rev pole.
to know you have the right wires....
cut one, and both lock and UL should stop working on the switch.
connect that wire back up , and cut the other wire... same test.
To keep the switch side/ solenoid sides straight:
with one of the wires cut... press the switch, and test with your DMM ( on DC volts)... the side that (still) lights up with + 12 volts is the switch side.
same test for the other wire...
good luck :)
Posted By: SNIPE22
Date Posted: April 13, 2004 at 6:49 PM
well I did that already on the pnk / YELLOW and pnk/lightgreen and when I press the lock switch I can see with the Voltmeter that the right side of the cable that I cutted  is the switch side because it is getting power when I press the lswitch to the lock position but when I try on the same cable just the opposite side you know the one that is suppostu be going to the motor when I  press the swtich to the unlock position, once again I see that it is getting power just as before but this is the lock cable not the unlock wirer same thing on the pnk/light green so I am not sure what to do I try on the other cables the pnk/orange and same thing  and yes I did try the reverse polarity door lock system and it didn't work I will try from the passenger side since the PNK / YELLOW & PNK/LIGHT GREEN go to the front passenger switch and from there it goes to the motors like i said before the wirers become a different color.
Posted By: SNIPE22
Date Posted: April 15, 2004 at 3:13 PM
can anyone help me ?
