hood and trunk. sharing the same zone?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30602
Printed Date: March 30, 2026 at 11:42 AM
Topic: hood and trunk. sharing the same zone?
Posted By: Pooreclipse
Subject: hood and trunk. sharing the same zone?
Date Posted: April 18, 2004 at 12:28 PM
Does anyone know do I need a diode to do this, if so, how do I see it up?
I want either the trunk pin or hood pin to trigger one of the zones.  Can they all just joint at the wire on the alarm?
Posted By: auex
Date Posted: April 18, 2004 at 7:14 PM
You should use diodes whenever you tie together multiple triggers. You can do it without the diodes but lights will turn on and dash indicators will turn on whenever one of the triggers is open.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: April 18, 2004 at 8:32 PM
So do I need n-1 diode or n dioles?  in otherwords does the original one need a diode?
Also if you could tell me.. does the band side face the door pin or the alarm?
