wirin diagram for stratus 2002
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3069
Printed Date: March 27, 2026 at 10:57 PM
Topic: wirin diagram for stratus 2002
Posted By: maucastro76
Subject: wirin diagram for stratus 2002
Date Posted: August 25, 2002 at 9:52 PM
hope sombady will help me. i´m looking for the wiring diagram for the dodge stratos 2002, i´m ytrying to install a hornet 700t alarm.
cr accesorios
Posted By: Velocity Motors
Date Posted: August 25, 2002 at 10:46 PM
NOTE THIS IS FOR THE COUPE NOT THE SEDAN. The wire colors are different for these nodels. Please let me know if you need the sedan if this is not what you need:
|              12V|WHITE/ red           |+  |ignition harness            |
|          STARTER|BLACK/ red           |+  |ignition harness            |
|         IGNITION|dk. green           |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
| SECOND ACCESSORY|blue/black          |+  |ignition harness            |
|       POWER LOCK|lt. GREEN/ black *2  |-  |drivers kick panel *1       |
|     POWER UNLOCK|orange *2           |-  |drivers kick panel *1       |
|       LOCK MOTOR|lt. green           |   |drivers kick panel *1       |
|     UNLOCK MOTOR|dk. GREEN/ red       |   |drivers kick panel *1       |
|    DISARM DEFEAT|blue/black          |   |passenger kick panel or *9  |
| PARKING LIGHTS +|grn/wht or pnk/blk  |   |low in drivers kick         |
|       HEADLIGHTS|orange              |-  |headlight relay under hood  |
|     DOOR TRIGGER|GREEN/ YELLOW        |-  |fuse box *8                 |
| DOME SUPERVISION|GREEN/ orange        |-  |fuse box *3                 |
|  TRUNK/HATCH PIN|red                 |-  |drivers kick panel *7       |
|TRNK/HTCH RELEASE|GREEN / WHITE         |5wi|drivers kick panel *7       |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|*6                  |   |                            |
|       TACHOMETER|*4                  |   |*4                          |
|      SPEED SENSE|WHITE/ blue          |   |center console *5           |
|       BRAKE WIRE|GREEN/ orange        |+  |brake pedal switch          |
|     HORN TRIGGER|lt. GREEN/ black     |-  |steering column             |
|           WIPERS|blu/org & blu/yel   |+  |wiper motor                 |
|  LF WINDOW UP/DN|RED / blk - grn/blk   |A  |drivers window switch       |
|  RF WINDOW UP/DN|RED / wht - green     |A  |drivers kick panel *1       |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|        RADIO 12V|ORANGE / black        |+  |radio                       |
|     RADIO SWITCH|WHITE/ black         |+  |radio                       |
| RADIO ILLUMINATE|GREEN / WHITE         |+  |radio                       |
|       LF SPEAKER|wht/blu - blk/blu   |   |radio                       |
|       RF SPEAKER|wht/red - blk/red   |   |radio                       |
|       LR SPEAKER|yel/blu - gry/blu   |   |radio                       |
|       RR SPEAKER|yel/red - gry/red   |   |radio                       |
Notes:
Note:  This vehicle is equipped with an immobilizer.  .  *1 Located in a black 32 pin plug.  *2 These are the door key cylinder wires. Meter the wires while turning the key in the drivers door. Unlock requires a double pulse. On vehicles without the factory alarm use purple for lock and lt. GREEN/ red for unlock, these are the door lock switch wires.  *3 In the plug on the upper right side of the fuse box under the driver side dash.  *4 Go to the test connector inside the fusebox under the hood, it is a T shaped plug. Tach is the terminal on the top left of the T, the wire under the terminal is white or WHITE/ red.    *5 Located in a large white 38 pin plug behind the radio.  *6 To disarm without unlocking, use a single pulse on the unlock wire.  *7 Located in a white 43 pin plug.  *8 Located in a black 19 pin plug on the back of the fuse box under the driver side dash.  *9 Also found in a black 20 pin plug on the front of the fuse box under the driver side dash.
