89 cressida alarm/remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30707
Printed Date: May 13, 2026 at 3:20 AM
Topic: 89 cressida alarm/remote start
Posted By: michaeltam2k
Subject: 89 cressida alarm/remote start
Date Posted: April 19, 2004 at 9:39 PM
Please help me which wire is the tach wire for my 89 toyota cressida ? i know is at the test connector but where is it ? and my car comes with anti theft system and which wire and where is the disarm defeat ? thank you so much for your help .
Posted By: draasch
Date Posted: April 19, 2004 at 9:44 PM
Remote Start
Tach Signal BLACK / YELLOW AT IGNITER OR DIAGNOSTIC PLUG
Ignition #2 BLACK / YELLOW IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light
Reverse Light RED / BLACK (+) AT SWITCH
Rear Window Defrost
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: April 19, 2004 at 9:53 PM
where is the IGNITER OR DIAGNOSTIC PLUG  ? and do you know where is the disarm defeat wire ?
Posted By: draasch
Date Posted: April 19, 2004 at 10:10 PM
OEM Alarm Disarm BLU/WHT (-) DOOR JAMB HARNESS
look under the hood, you should see a small module the says igniter right on it
Good Luck
David
Ace Security
813-376-9778
Tampa
Posted By: profuse007
Date Posted: April 19, 2004 at 10:23 PM
may want to look for the igniter mounted at the driver's strut tower
Houston,TX
Date Posted: April 25, 2004 at 9:13 PM
I istall my Prestige APS-55LRA in my 89 toyota cressida today but everything works but except when i remote start it  the parking light flashes but the car won't start .what am i missing there ..please anyone help me ...thanks alot
Posted By: bmf1000d
Date Posted: April 25, 2004 at 10:25 PM
You sure you have all you ign wires powered up?
Does it even crank over?
Is it a manual?
Here is the diagram that i have for that car
Toyota
Cressida
1989-1992
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
BLACK/ WHITE
Ignition #1:
BLACK/ RED
Ignition #2:
BLACK / YELLOW
Ignition #3:
N/A
Accessory:
Brake Light:
GREEN / WHITE(+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
BLACK / YELLOW
Parking Lights:
GREEN
(+) AT FUSE BOX
Headlights:
OEM Alarm Disarm:
BLUE/WHITE (-)
THEFT MODULE LEFT OF STEERING COLUMN
OEM Alarm Arm:
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
Toyota
Cressida
1989-1992
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
WHITE/ RED OR WHITE
Starter Kill:
BLACK/ WHITE
Ignition +12 Volts:
BLACK/ RED
Dome Lights/Superv:
RED / WHITE
(-) AT FUSE BOX
OEM Horn:
GREEN/ RED (-)
STEERING COLUMN HARNESS
Power Lock:
GREEN
DRIVER'S KICK PANEL *
Power Unlock:
RED / YELLOW OR BLUE
Trunk Release:
Alarm Input Wire:
RED / WHITE
(-) AT FUSE BOX
Notes:
* See Note #201 - Negative Pulse Door Lock Diagram.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Date Posted: April 25, 2004 at 11:04 PM
now that when had it start but my factory alarm sets off when i remote start my car . do you know how to by pass that factory alarm ..thanks alot
Date Posted: April 25, 2004 at 11:46 PM
 where is the DOOR JAMB HARNESS ? thanks
