keyless entry, 2000 camry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30724
Printed Date: May 12, 2026 at 10:43 PM
Topic: keyless entry, 2000 camry
Posted By: marvel
Subject: keyless entry, 2000 camry
Date Posted: April 20, 2004 at 7:53 AM
i have installed a keyless entry device in my 2000 camry but i want to put a trunk release option which is already in my KE device. will i need to buy an actuator for my trunk and drill it in. what wire guage will i use and is there a specific type of actuator for it that i need to buy. do i need relay?thanks
turbo
Posted By: raydawg357
Date Posted: April 23, 2004 at 2:13 PM
Does your car have a push button trunk pop or a lever?  You can find trunk pop kits at most install shops that can be wired to your KE.
Do it right the first time
Posted By: Javelin3o4
Date Posted: April 23, 2004 at 4:02 PM
you would have to get one of those trunk release solenoid kits.
Posted By: marvel
Date Posted: April 25, 2004 at 2:51 AM
Thanks 4 ur reply. i have a lever type trunk release. can it be converted to adapt in my ke
turbo
Posted By: profuse007
Date Posted: April 25, 2004 at 11:08 AM
heres one site that sell them solenoid
get a relay and a prewire harness to go along w/ the solenoid.
Houston,TX
