Security/Anti-Theft System for Chrysler
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30916
Printed Date: May 11, 2026 at 10:04 AM
Topic: Security/Anti-Theft System for Chrysler
Posted By: kelker
Subject: Security/Anti-Theft System for Chrysler
Date Posted: April 23, 2004 at 2:27 PM
I have a 1992 Chrysler New Yorker Fifth Avenue. I never activate the security system, yet sometimes when I open the door, the horn starts beeping, lights flash, and I have to close the door, lock it with the key, then unlock to stop everything! The system just starts on its own and is a pain in the neck. Is there a way to disconnect this system? It came with the car when it was brand new off the show room floor. Thanks
------------- sailor2
Posted By: tonto26
Date Posted: April 24, 2004 at 10:48 AM
Go over to the Chrysler dealership, and get a remote for it.
Posted By: kelker
Date Posted: April 25, 2004 at 5:26 AM
Thanks for your advice, but I want to "disable" the system permanently because it shouldn't activate on its own when I don't turn it on in the first place. The doors are unlocked, and when any one of the doors is opened, it starts doing its thing! Then you have to close the door, use the key to lock and unlock the driver's door to get it to shut off.
Posted By: eurotech
Date Posted: April 26, 2004 at 7:14 PM
The factory alarm in your car is located above the glovebox. Find the lt. GREEN/ orange wire coming out of the brain...then tap into this wire and ground it. This will disable the factory alarm permanently!
