RS Antenna from Prestige to DEI
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=30970
Printed Date: May 10, 2026 at 3:06 PM
Topic: RS Antenna from Prestige to DEI
Posted By: Dteg
Subject: RS Antenna from Prestige to DEI
Date Posted: April 24, 2004 at 8:25 PM
I installed an Audiovox 966a and it works but the range is dissapointing. I was wondering if I it would help any if I switched to the DEI antenna, they both use 4 pins on thier plugs, DEI  is about 3 times longer that that stubby one that comes with the Prestige 966a. Let me know if it possible.
Posted By: AutoObsessions
Date Posted: April 26, 2004 at 12:51 AM
I am not sure if you are even able to use a dei antenna with this system. There might be a problem with your system or just a bad antenna even though I have never encountered a problem with these. The last one of these that I installed I was able to start the car from 5 blocks away.
Posted By: Dteg
Date Posted: April 27, 2004 at 5:13 PM
 I really don't think the alarm is defective I just think the range sucks.  I forgot where I read the range on the APS 966a is only about 1000'.  If I had a 5 block range I would be very happy.  I'll live with it for now but I will upgrade when I find a good deal on a better unit  in the future.
Posted By: jfk51502003
Date Posted: April 27, 2004 at 5:41 PM
WHERE IS ANTENNA MOUNTED...?
Posted By: Dteg
Date Posted: April 27, 2004 at 5:44 PM
On the windshield upper center area
Posted By: godsegoizhuge
Date Posted: April 27, 2004 at 8:32 PM
try moving the antenna. sometimes that helps, esp if the car has some sort of factory tint at the top.
