Directechs info for 2 cars please.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31064
Printed Date: May 10, 2026 at 8:52 AM
Topic: Directechs info for 2 cars please.
Posted By: ErickSaint
Subject: Directechs info for 2 cars please.
Date Posted: April 26, 2004 at 1:25 PM
Looking for the directechs info for a 1998 Ford Expedition and a 2004 Nissan Sentra.
Somebody posted the directech info for my car for me a few months ago...hoping to get the same info for the above cars.
Thanks in advance.
Erick
Posted By: raydawg357
Date Posted: April 27, 2004 at 9:24 AM
12volts
posted_image
WHITE/ red (40A)
posted_image
posted_image
ignition harness
StarterBLACK/ white + ignition harness
Second StarterBLACK / YELLOW + ignition harness
IgnitionBLACK/ red + ignition harness
Second IgnitionN/A
Third IgnitionN/A
Accessorywhite + ignition harness
Second AccessoryWHITE/ blue + ignition harness
Keysenseblue/white + ignition harness
Power Lockgray - SECU right of column, pin 23
Power UnlockPURPLE / red - SECU right of column, pin 35
Lock MotorRED / black 5wiSECU right of column, pin 15
Unlock Motorblue/red 5wiSECU right of column, pin 13
Parking Lights+WHITE/ red or RED / blue + headlight switch or driver kick
Parking Lights-N/A
HazardsORANGE / black (w/keyless only) - SECU right of column, pin 7
Turn Signal(L)GREEN/ black + steering column
Turn Signal(R)GREEN/ YELLOW + steering column
Reverse LightGREEN/ YELLOW + driver kick, harness to rear
Door Triggersee notes - SECU right of column
Dome SupervisionRED / yellow - SECU right of column, pin 8
Trunk/Hatch PinRED / black - SECU right of column, pin 38
Hood PinN/A
Trunk/Hatch Releasered - trunk release switch
Power Sliding DoorN/A
Factory Alarm Armlt. GREEN/ red - SECU, right of column, pin 41
Factory Alarm DisarmWHITE/ blue - SECU, right of column, pin 30
Disarm No Unlocksee factory alarm disarm
TachometerNOT GREEN / WHITE or BLACK/ yel ac any ignition coil
Wait to startN/A
Brake WireRED / green + brake pedal switch
Parking Brakeyellow/black - parking brake switch or driver kick
Horn TriggerWHITE/ green - steering column or SECU, pin 19
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
Immobilizer Bypass Module
posted_image
MAKE : NISSAN | MODEL : SENTRA | YEAR : 2004
* The logo is registered trade mark of Nissan Corporate.
Do it right the first time
Date Posted: April 27, 2004 at 9:27 AM
12volts
yellow, grn/purple
ignition harness
StarterRED / lt. blue + ignition harness
Second Starter
Ignitionblue/lt. green + ignition harness
Second Ignitiongray / YELLOW(2nd acc) + ignition harness
Third Ignition
AccessoryRED / black + ignition harness
Second AccessoryBLACK/ green + ignition harness
Keysense
Power Lockpink / YELLOW - keyless module
Power Unlockpink/green - keyless module
Lock Motorpink/black drivers kick panel
Unlock MotorRED / orange drivers kick panel
Parking Lights+brown at light switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Triggerlt. blue/white - keyless module
Dome SupervisionBLACK/ lt. blue + passenger kick panel
Trunk/Hatch Pintied in with door
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm ArmN/A
Factory Alarm DisarmN/A
Disarm No UnlockN/A
TachometerWHITE/ pink ac engine harness
Wait to start
Brake Wiregreen + at brake switch
Parking Brake
Horn Triggerdk. blue - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
posted_image
MAKE : FORD | MODEL : EXPEDITION | YEAR : 1998
Date Posted: April 27, 2004 at 9:42 AM
Thanks a ton, exactly the info I was after.
But a quick question...for the Sentra it says the tach wire is NOT GREEN / WHITE or BLACK/ yel, so is there another wire at the coils that I should be looking for?
Anyone done an 04 sentra that can give me some tips?
Posted By: eurotech
Date Posted: April 27, 2004 at 4:18 PM
There should be two wires coming out from each coils...use any of them except the ones specified.
Date Posted: April 28, 2004 at 9:41 AM
Exactly what I thinking...thanks for clearing that up.
