alarm install solder? and probe question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31145
Printed Date: May 11, 2026 at 6:25 AM
Topic: alarm install solder? and probe question
Posted By: Pooreclipse
Subject: alarm install solder? and probe question
Date Posted: April 27, 2004 at 4:08 PM
I talked to many many installer they told me they dont' solder.  Of course their time is money
but I've got time..  so I think I should solder everything instead of vampire taps..?
BTW, when it say find a wire, how do you probe it without cutting the insulation or cutting it?
Not always you can get to the harness itself.
Posted By: Teken
Date Posted: April 27, 2004 at 4:20 PM
Not much of an installer IMHO. . .
They will definately have the time to redo the same job. Now who is making or losing money???
Pooreclipse wrote:
but I've got time..
Good . . .
Solder and heat shrink or use high quality 3M 33+ or 60 electrical speed tape . . .
You will use the end of the probe and pierce the insulation with the tip of the probe.
Regards
EVIL Teken . . .
Posted By: eurotech
Date Posted: April 27, 2004 at 4:23 PM
soldering is a good idea,,,as long as you tape or shring wrap everything good.  Ive seen a few bad solder jobs smoke ign harnesses!  As far as testing wires- just get a hooked pick tool to support the rear of the wire you are testing and a sharp test light or meter end and poke through the insulation.  this only leaves a small hole
