starter interrupt
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31305
Printed Date: May 12, 2026 at 8:44 PM
Topic: starter interrupt
Posted By: davidwp13
Subject: starter interrupt
Date Posted: April 29, 2004 at 6:33 PM
 Hi I have a Python 660XP and have the AED ( interrupt ) hooked to the right wire, I think when I unplug the relay it will not atart,BUT how do I know if it is working properly?
 I did ENABLE it by using the valet and the remote to get 1 BEEP.
 ANY HELP??
David
Posted By: draasch
Date Posted: April 30, 2004 at 3:22 PM
i dont use that brand, however i would think you can set the alarm and then trigger it and while the alarm is sounding, see if you can start the car.......
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: kgerry
Date Posted: April 30, 2004 at 3:43 PM
ROLL DOWN THE DRIVERS WINDOW, ARM THE ALARM AND REACH THRU AND TRY TO START IT WITH THE KEY.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
