Peugeot 306 1997 alarm wiring diagram req
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31575
Printed Date: May 16, 2026 at 1:49 AM
Topic: Peugeot 306 1997 alarm wiring diagram req
Posted By: Nick-a
Subject: Peugeot 306 1997 alarm wiring diagram req
Date Posted: May 04, 2004 at 11:58 AM
Many thanks!
Nick
Posted By: auex
Date Posted: May 04, 2004 at 6:59 PM
Here is what I could find for a 96.
12volts
Starter blue      ignition harness
Ignition yellow      ignition harness " Fuel cut pump is white wire at a double relay module attached to the firewall on the n/side. Module is brown."
Power Lock orange or white    -   ctrl mod behind rear seat Extend to 3 second lock pulse to deadlock
Power Unlock violet or lt brown    -   ctrl mod behind rear seat Extend to 3 second lock pulse to deadlock
Parking Lights+ red & green      at the steering column
Door Trigger grey or yellow    -   loom driver side A pillar
Trunk/Hatch Pin white      at the bootlight
Tachometer brown pin 4      yel conn. top of the dash
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Nick-a
Date Posted: May 04, 2004 at 7:21 PM
Cheers for that, should make life a bit easier.
Regards,
Nick
Posted By: Nick-a
Date Posted: May 13, 2004 at 11:21 AM
Hi,
Can anyone tell me what door locking system it has (to fit a clifford Avang Guard, 5) everythings done apart from the door locks and brake light now!
Regards,
Nick
Posted By: laren5
Date Posted: May 14, 2004 at 5:51 AM
Type B:  negative
Good luck
Clifford Alarms
Posted By: Nick-a
Date Posted: May 21, 2004 at 2:57 PM
Right...done everything now apart from the remote start, it has a problem. If the cars running and i activate remote start, and turn it off, it waits a second or two and restarts the car without the key etc, but wont do it without the key having been in the ignition when its activated. I can start the car using the manual elements of cliffnet too, but the start command itself does nothing. It can read the RPM. battery etc everything! Any ideas on what to try?
Cheers Guys,
Nick
Posted By: audioconnection
Date Posted: May 25, 2004 at 11:01 PM
i believe you have to bypass the safety feature of the clifford. it has this to stop people starting cars with them in gear. and the pug prob doesnt have a parking lock if its an auto.
if you need local help, call PDS in Fenton, Staffs @ 01782-744556
or paul @ source sounds in sheffield
remember...Friends Dont let friends Install, Take it to a pro..
Posted By: Nick-a
Date Posted: May 26, 2004 at 10:05 AM
All sorted now :)
Ta,
Nick
