2001 chevy silverado--diode
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31826
Printed Date: May 14, 2026 at 2:12 AM
Topic: 2001 chevy silverado--diode
Posted By: revmatt99
Subject: 2001 chevy silverado--diode
Date Posted: May 08, 2004 at 7:11 PM
another question i had.. when i installed my alarm the crimeguard 533i3 i didnt diode isolate the door trigger wires. Do i need to do that? what will it cause if I dont do that? please explain.. I am a newbie! thanks ahead of time.
Posted By: rudbwoy69camaro
Date Posted: May 09, 2004 at 11:03 AM
when the key is in the ignition(engine off), and you open the driver door-you should hear the chime only.  if  not diode isolated, when the key is in the ignition(engine off), you'll hear the chime when you open the passenger door.
