94 accord factory wiring for remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32375
Printed Date: May 08, 2026 at 11:27 PM
Topic: 94 accord factory wiring for remote start
Posted By: laupek
Subject: 94 accord factory wiring for remote start
Date Posted: May 19, 2004 at 2:24 AM
 i get the wiring code here for remote start which show ACC is yellow wire and Ignition 2 is WHITE/ black wire.....but i checked it at my factory service manual page 23-62 ( in case someone also have one and wanna refer ), it show that ACC is WHITE/ black and Ignition 2 is yellow.......i followed the factory one....and every thing work great...just wonder.. when i remote started the car before inserting the key, the ABS light stays on but just after i inserting the key and turn to On(II)  position, the ABS light goes right away....is this normal or because of the wiring above?
94 Accord Ex Coupe
Small Vtech
Posted By: profuse007
Date Posted: May 19, 2004 at 3:28 AM
manually test each wire for sure, dont just plug and chug....
Houston,TX
Posted By: raydawg357
Date Posted: May 19, 2004 at 6:07 PM
Your ignition is BLACK / YELLOW and your accy is yellow
Do it right the first time
Posted By: laupek
Date Posted: May 19, 2004 at 9:36 PM
ya..i got it switched around...it work..the ABS light off when the car is remote started....
94 Accord Ex Coupe
Small Vtech
