1995 toyota land cruiser
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32419
Printed Date: May 04, 2026 at 10:37 AM
Topic: 1995 toyota land cruiser
Posted By: A & E AUDIO
Subject: 1995 toyota land cruiser
Date Posted: May 19, 2004 at 9:22 PM
trying to install a remote start alarm in a 1995 land cruiser wont turn over alarm book says something about toyotas having a "ignition (2) on through cranking wire. diagram says that BLACK/ green is ignition #2 but this does not work?????? help please......
Posted By: mark mcj
Date Posted: May 19, 2004 at 9:47 PM
If the starter won't turn at all it sounds like the starter wire isn't getting 12 volts. My referance showes the starter as being black with a white strip.
mark mcj
Date Posted: May 19, 2004 at 9:52 PM
sorr the starter is turning ut the car wont start. it seems like the fuel pump kay not be comming on or something to that effect..
Posted By: raydawg357
Date Posted: May 20, 2004 at 1:30 PM
12volts black - WHITE/ red   +  ignition harness
Starter BLACK/ white   +  ignition harness
Second Starter
Ignition BLACK / YELLOW   +  ignition harness
Second Ignition blk/grn or blk/red   +  ignition harness
Third Ignition
Accessory blue/red   +  ignition harness
Second Accessory
Do it right the first time
Posted By: mark mcj
Date Posted: May 20, 2004 at 10:16 PM
posted_imageThis should do the job. I was pretty warm today and now I have consumed several adult beverages. If anyone sees a screw up feel free to speak up.
mark mcj
Posted By: mark mcj
Date Posted: May 20, 2004 at 10:31 PM
Sorry for the confusion. I posted this reply in the wrong topic. LOL!!
mark mcj
Posted By: Velocity Motors
Date Posted: May 20, 2004 at 11:00 PM
Check to make sure that your getting 12 volts on your starter output wire from the remote starter first. Next, make sure that your ground is secure and free of dirt, grease and paint.
