Light Switch Wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32639
Printed Date: May 07, 2026 at 9:08 AM
Topic: Light Switch Wire
Posted By: TopCrusader
Subject: Light Switch Wire
Date Posted: May 24, 2004 at 3:19 AM
Hi;
Usually I leave the headlights on in my 98 Camry. When I open the Drivers door they go off automatically. When the car is started, they come back on if they were left in the "On" position
I just installed an Autopage Remote Starter. When the remote starter starts the car, the lights come on if they were left in the "On" position. The problem is, if the remote starter times out after 10 minutes, or I get hung up on my way to the door and cant leave, the lights are now left on because the drivers door hasn't been opened to trigger the automatic shut off. Any Idea what wire controls this auto shutoff so I can tap into it?
Thanks Pat
Posted By: Velocity Motors
Date Posted: May 24, 2004 at 10:39 AM
If the Autopage system has a wire that can be programmed to pulse after remote start, attach this wire to the door trigger wire. If it doesn't have this wire, then what you can do is to hook up the door trigger wire to one of the UAX channels and you can use this to pulse a signal to the door trigger wire to fool the car into thinking that the door was opened.
------------- Jeff
