viper 690 xv in 90 cadillac brougham
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32654
Printed Date: May 07, 2026 at 12:55 PM
Topic: viper 690 xv in 90 cadillac brougham
Posted By: brougham
Subject: viper 690 xv in 90 cadillac brougham
Date Posted: May 24, 2004 at 12:04 PM
time to put an alarm on my caddy and im gonna do it myself this time. i have never done an alarm but i can do stereo and i have an electronic/electrical background. so im puttin this viper 690 xv, anything i need to know? will the alarm come with instructions? and where can i get complete diagrams of everything i will need?  thanks.
Posted By: CutDog504
Date Posted: May 24, 2004 at 12:33 PM
Your alarm will come with pretty detailed instructions, so it shouldnt be too hard. You will have to splice into many of your wires in the drivers side dash, in the steering column harness, and the kick panel. The wiring for a 90 caddy brougham is as follows:
WIRE---------color---------location----------------
12Volts......RED...........Ign harness
Ign 12v......pink..........Ign harness
Ign 2........orange........Ign harness
Accsy........Brown.........Ign harness
Tach.........white.........at distributor
Starter......purple........Ign harness
Brake(+).....light blue....switch above brake pedal
dome light(-).white........At any pinswitch or ctsy light
trunk pin(-)..dark green...instrument cluster
trunk release(+)..black....at trunk release switch
parking lights(+)..brown...at headlight switch
power lock(+)....light blue..driver kick panel*
power unlock(+)...black......driver kick panel*
*Positive pulse doorlocks
Posted By: brougham
Date Posted: May 24, 2004 at 12:39 PM
thanks.
sorry for the double post.
Posted By: madmods
Date Posted: May 25, 2004 at 12:19 AM
The install and owner manual can be downloaded for free at DEI website.
Posted By: brougham
Date Posted: June 08, 2004 at 8:28 AM
im installing a viper 690xv in a 90 cadillac brougham. this is my first install of an alarm and i got a few questions.
the white wire is supposed to go to the parking light and my vehicle wiring guide off here says thats the brown wire on the light switch - i cant find this wire, im guessing this is what makes the lights blink when it arms.
also where and how is a good place to mount the shock sensor. i dont think there are any mounting tabs on the sensor itself and i would think you have to have a solid mount to the body.
thanks for any help.
Posted By: brougham
Date Posted: June 08, 2004 at 9:35 AM
also there is a small pot on the shock sensor, im guessing its for sensetivity adjustement. which way is more sensitive? CW or CCW?
Posted By: Velocity Motors
Date Posted: June 08, 2004 at 9:50 AM
Look for the BROWN parking light wire low in drivers kick panel. The shock sensor you can mount on any flat surface or on a large loom of wires. If the shock sensor is upright, if you turn it CW it will make it more sensitive.
Posted By: kgerry
Date Posted: June 08, 2004 at 9:52 AM
wire tie the shock sensor to a good wire loom under the dash, usually CW is increasing sensitivity and CCW decreases.   If you cant find the brown wire at the light switch, then turn on the parking lights only and meter the wires at the switch unitl you find one with 12 Volts on it, turn off the lights and see if it dumps voltage . If it does use this wire....    almost all older GM's use a brown wire for parking lights so it should be there.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: brougham
Date Posted: June 08, 2004 at 11:23 AM
thanks for the help. i should be able to take it from here.
Posted By: brougham
Date Posted: June 08, 2004 at 12:14 PM
i still cant fond the right brown wire. there is like 10 brown and light brown wires. i found one that had 12v when i turned on the headlights so i hooked it up but my lights didnt flash when i armed it. should i be looking for 12v when the headlights are on? i dont know how to turn the parking lights on. any more help?
Posted By: kgerry
Date Posted: June 08, 2004 at 1:59 PM
not headlights... parking lights....you want a wire with 12 volts only when the PARKING LIGHTS are on.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Posted By: brougham
Date Posted: June 08, 2004 at 3:14 PM
i dont know how to make the parking lights come on.  are they on when the car is running and in park?
Posted By: kgerry
Date Posted: June 09, 2004 at 11:43 AM
pull the headlight switch one notch, that should turn on the parking lights only (with dash lights).. go look...are they on?  the second notch/push/pull on the switch will activate the headlights... you want parking lights only
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
