2004 1/4 Ford F-250 Diesel
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32697
Printed Date: May 07, 2026 at 10:09 PM
Topic: 2004 1/4 Ford F-250 Diesel
Posted By: tsu708
Subject: 2004 1/4 Ford F-250 Diesel
Date Posted: May 25, 2004 at 2:01 AM
Does anyone have access to Wiring Diagrams for a Ford 2004 1/4 F-250 Diesel? I am installing a Clifford Matrix 3.5  Also does this vehicle need a pulse timer module?  Thanks
Posted By: raydawg357
Date Posted: May 25, 2004 at 10:30 AM
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES SUPER DUTY / 2004 / Remote Start
[PRINT THIS PAGE]
12volts yellow & lt. GREEN/ purple  +  ignition harness
Starter green  +  ignition harness
Second Starter N/A
Ignition RED / lt. green or WHITE/ yellow  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW & RED / black  +  ignition harness
Second Accessory blue/lt. green  +  ignition harness
Keysense
Power Lock see notes
Notes: Without keyless entry use pink / YELLOW for lock and pink/lt. green for unlock. They are 5 wire reverse polarity mastered from the driver switch and found in either kick panel. With keyless entry use WHITE/ red for lock and BLACK/ white for unlock. They are negative trigger and found at the VSM.
On the vehicles with keyless entry the GEM shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1094.
Power Unlock see power lock notes
Lock Motor pink/black  5wi VSM
Notes: The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Unlock Motor RED / orange  5wi VSM
Parking Lights+ brown  +  headlight switch
Parking Lights- N/A
Hazards same as turn signals
Turn Signal(L) lt grn/wht (F), lt grn/org (R) +  steering column
Turn Signal(R) wht/lt blu (F), org/lt blu (R) +  steering column
Reverse Light BLACK/ pink  +  fuse box
Door Trigger BLACK/ lt. blue  +  passenger kick panel
Dome Supervision use door trigger
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer NOT RED / lt. green  ac  any ignition coil
Notes: On diesel vehicles the tach wire is GREEN / WHITE in a 5 wire harness held up with white tape behind the parking brake release.
Wait to start see DirectFax document 1091
Brake Wire lt. green  +  brake pedal switch
Parking Brake lt. GREEN/ red  -  parking brake switch
Horn Trigger blue  -  steering column or VSM
Memory Seat 1 BROWN / lt. green  -  memory mod under dr seat
Memory Seat 2 BLACK/ orange  -  memory mod under dr seat
Memory Seat 3 N/A  -
posted_image
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
Do it right the first time
Date Posted: May 25, 2004 at 10:32 AM
Here's the timer diagram: https://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1091.pdf
Posted By: tsu708
Date Posted: May 25, 2004 at 11:33 AM
Thank you Very Much for the Info.
