2001 tacoma car alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=32873
Printed Date: May 10, 2026 at 1:46 AM
Topic: 2001 tacoma car alarm
Posted By: damniforgot
Subject: 2001 tacoma car alarm
Date Posted: May 28, 2004 at 12:21 AM
i recently purchased a "The Guardian Two Way Car Alarm with LCD and Remote Start" you can see it at https://www.alarmacar.net/customer/product.php?productid=16141&cat=249&page=1.  i will be installing it in my 2001 tacoma.  i have never put in a car alarm but i am very mechanical, and about to find out how i fare at electrical.  i've done many a car stereo but never an alarm.  any helps tips would be appreciated, also if there is a wiring diagram out there for an 01 tacoma i would appreciate that.  thank you all for your time
bill
Posted By: Velocity Motors
Date Posted: May 28, 2004 at 12:24 AM
Hey Bill, if it's just an alarm system installation, the whole process is very simple. Just locate the proper wires and hook them up to the wires on the alarm system. The most important part of the installation is to make your wires look OEM and also to hide all the components of the alarm so that someone can not see the aftermarket installation.
Date Posted: May 28, 2004 at 12:32 AM
thanks for the reply you guys are great here, it's not just an alarm. heres a list of the stuff from the website "INCLUDES:
(1) BRAIN MODULE
(1) LCD PAGER REMOTES
(1) 6-TONE SIREN
(1) IMPACT SENSOR DUAL ZONE W/HARNESS
(1) 20 PIN WIRING HARNESS
(1) (12G.) WIRE HARNESS W/ 2 FUSE HOLDERS
(1) 3 PIN DOOR LOCK HARNESS
(1) 4 PIN WIRING HARNESS FOR SENSOR
(1) PUSH BUTTON SWITCH ANTENNA
FEATURES
2-way car alarm with LCD display
Long range FM system (up to 3000ft.)
Car/alarm status LCD display on remote
Visual and audio alert on remote
Dual zone monitoring shock sensor
Auto-lock/unlock
Anti car-jacking system
Doors/trunk/hood sensors
Remote engine starter
Auto re-locking
Trunk release by remote
Remote easy key-lock
Current sensing circuit
Status led
Silent arm/disarm
Flashing headlights
127db siren
Remote panic
Sensor bypass by remote
Valet/override functions
Starter disable output
i also already have a factory alarm, i don't know if this is a positive or a negative for me at this point but it shouldn't be too bad.  my main concern is to find a wiring diagram for the 2001 tacoma, is it the same as the '00??  i'm going to have everything torn apart any way the seats door panels everything, getting an all new system for my new baby.  thank you guys again so much for your help
bill
Date Posted: May 28, 2004 at 11:36 AM
Leave the factory alarm in the vehicle as you can just not use the OEM remote at all and it will not engage the system. The wiring is the same for the 2001 as it is for the 2000.
