Hood pin question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33167
Printed Date: March 29, 2026 at 1:10 AM
Topic: Hood pin question
Posted By: 12voltfan
Subject: Hood pin question
Date Posted: June 02, 2004 at 2:21 PM
My car does not have a hood pin and I want to add a remote start, is there a way to trick the alarm brain
into seeing the hood pin without actually having to install one.
Posted By: derek123
Date Posted: June 02, 2004 at 2:27 PM
most ( all ?) RS come with a hood pin.
you get a "drill a hole some where " hoodpin with the RS, but you could sub in a different style of hood pin that's less intrusive, if you're hyper-picky.
yes, you can bypass it, but don't, as it is a safety feature, for your protection.
Date Posted: June 02, 2004 at 2:45 PM
Thanks, I guess i was looking for a pin that some cars have to turn on a lamp under the hood and mine doesn't hav it. Makes sense now.
Posted By: draasch
Date Posted: June 02, 2004 at 4:25 PM
they also make brackets so that you dont have to drill a hole for the pin switch....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: deviousjoker
Date Posted: June 02, 2004 at 4:32 PM
just buy a mercury switch........it's a lot easier and it doesn't rust out over time.
First Class MECP Installer
