Stock Alarm Going Off Like Crazy
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33211
Printed Date: March 29, 2026 at 3:14 PM
Topic: Stock Alarm Going Off Like Crazy
Posted By: Thuan
Subject: Stock Alarm Going Off Like Crazy
Date Posted: June 03, 2004 at 5:34 AM
earlier today i removed the fuse for the ecu out of my girls 92 acura integra gsr...after i replaced the fuse the alarm goes off non stop..so i disabled the alarm by unplugging the fuses to the alarms power and ground...now the car is without a working alarm. it was working fine before but by any chance would anyone know how to get the alarm to function properly or what could be causing this? thanks
------------- Thuan
Posted By: onlyremotes
Date Posted: June 03, 2004 at 9:35 AM
What is the fcc# from the back of the remote(s)? How many buttons? ------------- Walton Guerrero-Installer/Distributor
Alltech Electronics,Inc
3732 Grissom Lane
Kissimmee, Florida 34741
autotechs.com onlyremotes.com
1-888-252-8324
"Always check your wires with a multimeter"
Posted By: Thuan
Date Posted: June 03, 2004 at 4:54 PM
FCC ID:H5LAL777A (2) Buttons : button #1 - to turn the alarm on/off with sounds button #2 - to turn the alarm on/off without sounds any help would be appreciated...thanks ------------- Thuan
Posted By: JWorm
Date Posted: June 03, 2004 at 8:04 PM
A 1992 Integra doesn't come with a factory alarm. Can you read the model number off the alarm brain?
Posted By: auex
Date Posted: June 04, 2004 at 12:20 AM
Well, it is made by Tekstar Corporation out of what looks like japan. Does it have a large button on the left and a smaller button on the right?
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Thuan
Date Posted: June 04, 2004 at 7:09 AM
both buttons are the same size....one is labeled I and the other II. i guess it doesnt come with a stock alarm but its sure acting like one. ------------- Thuan
Posted By: profuse007
Date Posted: June 04, 2004 at 8:02 AM
so the remote doesnt do anything when you press the button(s)?
------------- Houston,TX
Posted By: Thuan
Date Posted: June 04, 2004 at 4:09 PM
yeah, the remote doesnt do anything when i press the buttons....the light just lights up. still unable to get it to arm/disarm the vehicle. sometimes i can get it to arm the vehicle but i cant disarm it...funny shi*...well not too funny cause its stressin' me out but yeah.
------------- Thuan
Date Posted: June 05, 2004 at 10:29 PM
You need a new remote. What is the board# inside the remote? There may be a white sticker with a code on it. Meanwhile put the alarm in Valet mode ------------- Walton Guerrero-Installer/Distributor
3732 Grissom Lane
1-888-252-8324
