code alarms pro500+
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33292
Printed Date: May 14, 2026 at 6:21 AM
Topic: code alarms pro500+
Posted By: saliann
Subject: code alarms pro500+
Date Posted: June 04, 2004 at 11:52 AM
My name is Saliann and I'm new here I hope you can help. Please can anyone help? I've bought a code alarm pro 500+ but don't have the wiring instructions, it's a jumble of pretty coloured wired to me so can anyone help with any instructions as to which wire connects where??   Please posted_image posted_image
Thanks, tons.
Posted By: saliann
Date Posted: June 17, 2004 at 8:41 AM
OK if no one can help with the 500+ any chance of any advice on the wiring of the 400 and maybe we can work out the rest ourselves.   Thanks
Posted By: FYRHWK1
Date Posted: June 17, 2004 at 8:09 PM
I definitly don't want to steer you wrong here, so take note, the wiring colors I know are for connecting the 426 master module and not the pro 500, but hopefully code is smart enough to use the same colors in all of their products.
For the small gauge main harness on the brain, the colors i remember are Gray - hoodpin input, Blue - Instant trigger, Green - Doorpin, Purple + Doorpin, WHITE/ Blue - Channel 3 relay output, Brown + siren output, Orange - starter kill relay output, White Parking Light output, WHITE/ Red Parking light polarity input, BLACK/ White - Domelight supervision relay output, BLACK/ Gray - Wait to start input
The thick gauge wire harness has Red & RED / Blue, both are power sources and should go to a +12V source, Orange + Acessory output, Pink + ignition 1, Pink/White + Ignition 2, Purple to engine side of the starter wire, Green to the key side of thhe starter wire, BROWN / Red - Brake shutdown input.
Remember, this is just the wires I remember off the top of my head and it's for a different model alarm, I would personally call code and ask them to fax or email you a diagram before you start installing.
Posted By: swamprat323
Date Posted: June 17, 2004 at 8:30 PM
I have the 400 some were, have to look. But all the code alarms i have seen there is sticker on the back of the unit saying what wire is what.
Kyle
