coinside the alarm wires with my factory
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33326
Printed Date: May 13, 2026 at 6:05 PM
Topic: coinside the alarm wires with my factory
Posted By: jaxon23
Subject: coinside the alarm wires with my factory
Date Posted: June 04, 2004 at 9:33 PM
can someone make me a write up to match up the alarm wire to the correct factory wire for me...thank you so much for your time...some are pretty self explanatory but i just want to make sure 100% when i hook this up. also i will be getting a DEI 530T to roll my windows up and down and to roll them up when i arm my alarm if you could add those in with astriks (*) so i will know where to attach them when it gets in..thanks again guys. here are the wire codes
Ungo SR5000 wire codes
PRIMARY HARNESS
orange- (-) 500ma armed output
white- +/- selectable light flash output
WHITE/ blue- (-) remote start activation input
BLACK/ white- (-) 200ma domelight supervision output
green- (-) door trigger input , zone 3
blue- (-) multiplexed inout, zone 4
viloet- (+) door trigger input, zone 3
black- (-) chassis ground input
brown- (+) siren input
red- (+) constand power input
RED / white- (-) 200ma channel 2 output
SECONDARY HARNESS
light GREEN/ black- (-) factorydisarm/special accessory output
violet/black- (-) selectable channel 4 output
RELAY SATELLITE KEY SWITCH INTERFACE
red- (+) high current 12v input
pink- (+) output to ign circuit
orange- (+) output to accessory circut
purple- (+) output to starter circuit
pink/white- (+) output to second ignition circuit
REMOTE START HARNESS
blue- (-) staus/factory security rearm output
blue/black- (-) 200ma optional third ignition output
gray- (-) hood pinswitch shutdown wire
brown- (+) brake switch shutdown wire
violet/white- tach input wire
BLACK/ white- (-) neutral saftey switch input
DOOR LOCK HARNESS
green- (-) lock/ (+) unlock output
blue- (-) unlock/ (+) lock output
1998 Mitsubishi Eclipse wire codes
1998 Mitsubishi Eclipse Security Information
Constant 12V+ White Ignition Switch Harness
Starter BLACK/ Red Ignition Switch Harness
Ignition BLACK/ White Ignition Switch Harness
Ignition 2 Blue Ignition Switch Harness
Accessory Blue/Black Ignition Switch Harness
Tach BLACK/ Blue Or Blue/Black Coil Pack 2 Cylinder Setting
Neutral Safety Wire BLACK/ White (-) PCM behind Center Console
Brake Switch Green Brake Switch
Trunk Pin RED / Green Driver's Running Board
Parking Lights GREEN / WHITE (+) Driver's Kick Panel or Fuse Panel
Head Lamp Red (-) Light Switch
Factory Disarm RED / Green (-) ECU Passenger's Kick Panel
Door Trigger RED / Green (-) Courtesy Light or Driver's Kick Panel
Door Lock BROWN / White (-) Behind Fuse Panel or 20 Pin Connector High Driver's Kick Panel
Door Unlock Brown (-)
Driver's Lock Blue/Black Driver's Kick Panel
Driver's Unlock Blue/Red Driver's Kick Panel
Passenger Unlock Blue/Red Passenger's Kick Panel
Horn Wire GREEN/ Red (-) Steering Column
Windows Up LF=GREEN/ Red, RF=BROWN / Yellow
Windows Down LF=GREEN/ Black, RF=GREEN/ YELLOW
Posted By: jaxon23
Date Posted: June 05, 2004 at 8:45 PM
got it all done...works great
