Which resistor to use
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33428
Printed Date: May 12, 2026 at 11:06 AM
Topic: Which resistor to use
Posted By: casnj
Subject: Which resistor to use
Date Posted: June 06, 2004 at 10:16 PM
In my vehicle the lock motor wire is 5 volts DC when unlocking and 7 volts dc when locking.  I want to attach a device to the lock motor wire to trigger when it senses voltage.  The problem is it would sense voltage on lock and unlock.  I only want the action to happen on lock.  Do I need a resistor for this applicaiton?  How do I figure out which one is needed?
THANKS
Posted By: auex
Date Posted: June 06, 2004 at 10:20 PM
Uh... Resistors have nothing to do with this, diodes either. What exactly are you trying to do or accomplish?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: casnj
Date Posted: June 06, 2004 at 10:22 PM
i dont want my device to trigger when it sees the 5 volts.  I want it to trigger on anything over 5 volts say 6.
Basically i want to block the 5 volts
Posted By: casnj
Date Posted: June 06, 2004 at 10:38 PM
one more thing to add.. maybe I need a relay?
lock motor wire get 5 volts on unlock and 7 volts on lock
unlock motor wire get 5 volts on unlock
Posted By: xetmes
Date Posted: June 07, 2004 at 7:28 AM
you could do it with a resistive voltage divider, what kind of locking system is it? ! wire? if the polarity reverses you would be better off using that fact and not the voltage level...
Posted By: casnj
Date Posted: June 07, 2004 at 7:56 AM
heres alittle more info
(+) motor lock wire
      +5 VDC on unlock
      +7 VDC on lock
(-) motor wire
      +5 VDC on unlock
       nothing on lock
is the resistive voltage divider still a good candidate?  maybe a relay would be better.  what I need to happen is if lock trigger one device if unlock trigger another.  im thinking relay due to how they are used with alarms to get 2 outputs out of one.
If I can just figure out what I need to use, that would be GREAT :)
Posted By: JWorm
Date Posted: June 07, 2004 at 10:46 AM
what kind of car?
Posted By: casnj
Date Posted: June 07, 2004 at 11:57 AM
JWorm] wrote:
hat kind of car?
2003 Audi a4.  i have to use the motor wires for a reason!
Posted By: 9vdc
Date Posted: June 08, 2004 at 9:51 PM
hai,
about the motor,how is the funtion ?is it going forward during lock and revers at unlock.
(+) motor lock wire, is it realy gets a +vdc during unlock and lock?
