impulse 990
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3355
Printed Date: May 14, 2026 at 7:56 PM
Topic: impulse 990
Posted By: vinh766
Subject: impulse 990
Date Posted: September 05, 2002 at 3:07 PM
i know the impulse alarm isn't very popular among the installers here but i already made my mistake of buy it and installing it already. i just had a few questions w/ it if anyone was familiar w/ it.
1. the alarm auto-arms itself when i leave the car, is there a setting that i can choose so that i can make it lock or unlock when it arms itself? (is there a way to program it through the remote?)
2. how can i stop my alarm from arming itself. everytime i un-arm it, about 1 minute later, it arms itself again, how can i stop that? (is there a way to program it through the remote?)
3. how do i change the sensitivity level on my alarm? (i want to make it more sensetive)
Posted By: vinh766
Date Posted: September 06, 2002 at 9:24 AM
can somebody please help me, i would greatly appreciate it. thank you
Posted By: Velocity Motors
Date Posted: September 06, 2002 at 10:52 PM
There are 4 ( or 5 ) DIP switches on the side of the alarm system. SWITCH # 2 is for PASSIVE ARMING. Turn this switch to the OFF position and it will solve your problem.
To change the sensitivity you have to:
  • Hold the VALET switch when the car is OFF until the siren CHIRPS once
  • Exit the car and close the door within 5 seconds
  • Wait until the system CHIRPS 2 times in a row
  • WAIT 2 seconds and then hit the car as hard as you want the car to be hit before the alarm activates
  • The system will CHIRP to confirm that it has learned the new impact setting
Posted By: vinh766
Date Posted: September 07, 2002 at 1:19 AM
i also need to know how to stop my alarm from arming itself, or is that not possible? i don't want it to arm itself everytime i unlock it for about a minute or so. how can i stop that?
Date Posted: September 07, 2002 at 7:51 AM
Look at my above post in the beginning. This will stop the AUTO arming with the flick of the switch.
Posted By: vinh766
Date Posted: September 07, 2002 at 12:47 PM
so how do i allow the AUTO arming but without the auto locking? because everytime it arms itself rite now, it locks itself, how do i stop that?
Posted By: vinh766
Date Posted: September 07, 2002 at 1:22 PM
one more thing, can you tell me what each DIP does? thank you, you have been so much help
Date Posted: September 07, 2002 at 5:17 PM
No way around it....it's an EITHER / OR situation but not both. Does your unit have 4 or 5 dip switches ?
Posted By: vinh766
Date Posted: September 07, 2002 at 5:24 PM
my unit has 5 DIP swithces
Date Posted: September 08, 2002 at 9:09 AM
  • SWITCH # 1 : 1st Crank & Ignition Duration ON: Normal    OFF: Extended for DIESEL
  • SWITCH # 2 :  Passive ARMING   ON: ENABLED       OFF: DISABLED
  • SWITCH # 3 :  Ignition Triggered Door Locks       ON: ENABLED      OFF : No ignition controlled door locks
  • SWITCH # 4 :  Run Time Selection      ON : 15 minutes       OFF: 25 minutes
  • SWITCH # 5 :  Setting this switch to OFF will delete Auto Tach Sensor. DO NOT DELETE AUTO TACH SENSOR unless system is malfunctioning
