Where’s starter wire on 94-95 mustang?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33592
Printed Date: May 10, 2026 at 7:28 PM
Topic: Where’s starter wire on 94-95 mustang?
Posted By: Yung than
Subject: Where’s starter wire on 94-95 mustang?
Date Posted: June 09, 2004 at 8:26 PM
My ford mustang GT came with a Viper 500 code plus alarm already installed. However, it does not have starter kill/engine disable feature. I managed to buy the starter kill relay and wired the orange (-) armed output from the Viper alarm to the steering coloumn, but now I have no idea which is the starter wire I should cut? WHat color wire is it and is it a thin or thick wire? Should I trace the wires from the ignition lock? Thanks in advance.
Posted By: draasch
Date Posted: June 09, 2004 at 11:05 PM
94/95 mustang: Starter WHITE/ PINK IGNITION SWITCH HARNESS
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: June 10, 2004 at 12:42 PM
Thanks, I found it. Which stater disable relay set up? Is it the normally closed set up?
Date Posted: June 10, 2004 at 12:44 PM
Which relay set up for the starter interrupt from the following page:
https://www.the12volt.com/relays/page2.asp
Posted By: profuse007
Date Posted: June 10, 2004 at 4:59 PM
-normally closed.
-87a and 30 will be conduct aslong as the alarm is disarm.
Houston,TX
