1997 lexus ES 300 wiring problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33616
Printed Date: May 10, 2026 at 8:09 AM
Topic: 1997 lexus ES 300 wiring problem
Posted By: drtoofast
Subject: 1997 lexus ES 300 wiring problem
Date Posted: June 10, 2004 at 4:36 AM
Wow I am reposting this so you guys can read it, hopefully
the moderator will delete the original post [sorry about that]
I recently installed a Valet 554r on my wife 1997 Lexus ES 300 Every thing seems to be working ok but after it
Auto-starts the Radio and heating/AC display flash from a dim to a bright. However if I un-hook the parking light flash it dose not do it. I used the white wire in the primary harness switched to Positive [ + ] and tied it into a GREEN/ orange wire that comes off the bottom of the fuse block facing you as you look at it. Dose anybody know am I tied into the wrong wire? or do I need a negative pulse on a different wire? Or maybe a relay ? I am at a loss? I do know something is not hooked up right but I have no information to bale me out… Hopefully some of you pros know whats going on with this system and can help me out.
thanks alot
If it too fast your Too old...
Posted By: draasch
Date Posted: June 10, 2004 at 8:49 AM
repost............unreadable
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: deviousjoker
Date Posted: June 10, 2004 at 9:25 AM
it sounds like your parking lights are flashing when you start your car.......which is normal......you can program the system to have parking light output constant or pulsed......they come programmed from DEI for pulsed.
First Class MECP Installer
