remote start problems on a 1997 es 300
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33633
Printed Date: May 10, 2026 at 5:40 AM
Topic: remote start problems on a 1997 es 300
Posted By: drtoofast
Subject: remote start problems on a 1997 es 300
Date Posted: June 10, 2004 at 1:04 PM
Wow my last post the formatting looked like it got run over by a 18-wheeler, see maybe if you can read this a bit better?
I am installing a valet 554r remote start on my wife 1997 ES 300 after getting it all hooked up and pretty much taking what seems like half the car apart I think I might have a little problem?
Every thing seemed to be working fine until I tied in the parking light flash. Then after the car auto starts the display for the heater/AC and the radio flash from dim to bright? Here how I have it hooked up and hopefully somebody with far more knowledge than myself will bale me out.
my door unlock harness is set to positive and 1 of the wires from the alarm is tied into a RED / w a green stripe and the other is tied into a blue/w a white stripe. and yes it lock and unlocks the doors when you hit the remote. Now on my main harness I have a wire that is a selectable light flash output, it is jumped to throw a positive output and I tied it into a GREEN/ w a orange stripe. Oh by the way that wire was comming off of the fuse box in the front lower left corner and my lock wires where found on the drivers kick panal. now hopefully somebody can tell me where I am going wrong. If I disconnect the parking light flash I dont get the radio/heater flashing when the car auto starts???
hope somebody can help???
thanks
__________________
If it too fast your Too old...
Posted By: profuse007
Date Posted: June 10, 2004 at 1:17 PM
----next time if your post is messed up you can go back and edit the post, but b4 another post is posted.
anyways....
"it is jumped to throw a positive output and I tied it into a GREEN/ w a orange stripe"
-the default setting of all DEI product is (+). if youre to jump it, then youre on (-).
| PARKING LIGHTS +|grn/org or grn/blk |   |bottom of fusebox *4        |
*4 In a white connector just below the fuses with the wires exiting out toward you.
but if youre to use the (-) jumper for parkin light
| PARKING LIGHTS -|green               |   |steering column             |
Houston,TX
