dei 451 siren, water help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33643
Printed Date: May 10, 2026 at 8:05 AM
Topic: dei 451 siren, water help
Posted By: IMPORTDUDE
Subject: dei 451 siren, water help
Date Posted: June 10, 2004 at 4:04 PM
i covered it with foil before so i can clean engine bay out...
and after i was done it worked...
then i started the car and closed hood for 10mins
and now arlarm works but sounds low, and weird noise?
did i just kill it?
thanks!!!
i hope not
Date Posted: June 10, 2004 at 4:11 PM
ops its dei 514t siren!~
Posted By: profuse007
Date Posted: June 10, 2004 at 4:40 PM
check to see if you accidentally ground the (+) siren wire.
Houston,TX
Date Posted: June 10, 2004 at 5:39 PM
it has sound....just not like regular
its like before bok bok
and now its unt unt
Posted By: Javelin3o4
Date Posted: June 10, 2004 at 5:41 PM
is the ground for the siren ran into the car? or is it grounded by the screw holding the siren to the car? if its grouned with the siren mount try unscrewing it and regrounding it, also was the little black wire that just goes into a loop cut? if not you can cut it which usually makes it a little louder.
Posted By: Manoftools
Date Posted: June 10, 2004 at 6:04 PM
Also check your ground for the alarm itself... when your ground for the brain is bad the alarm will sound about a fourth as loud.
Date Posted: June 11, 2004 at 1:16 AM
wow thanks for all the resposnse...
i went to the mall for couple of hours and came back and it works like a charm now:)
thanks
