Omega and UltraStart?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33679
Printed Date: May 10, 2026 at 4:51 PM
Topic: Omega and UltraStart?
Posted By: ers1121
Subject: Omega and UltraStart?
Date Posted: June 11, 2004 at 9:18 AM
I have an OmegaMax Alarm / RS combo, it is made for an automatic trans only. I also have an UltraStart 1250M currently installed in my Ford Ranger w/ manny tranny. The r/s works great and it is made for a manual trans vehicle. Is there any way to use the Omega alarm to activate the the UltraStart R/S, or use the UltraStart to arm & disarm the Omega? What it comes down to is i'm trying to use this combo so I don't have to buy a whole new system. Any ideas appricated! Ed ------------- Ed
Posted By: deviousjoker
Date Posted: June 11, 2004 at 9:40 AM
you should have a negative activation input on the ultrastart......just use a channel of the omega to send the negative signal to the ultrastart..........but this should be cautioned it might bypass the extra security for the manual trans start.
------------- First Class MECP Installer
Posted By: draasch
Date Posted: June 11, 2004 at 9:52 AM
Ed
not sure i follow you. it sounds like you have the omega max already.....
no you can operate the max with the ulta start transmitters....
wgat type of ultra start do you have??
------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: markcars
Date Posted: June 11, 2004 at 10:01 AM
Looks like he's got the UltraStart 1250M that works for manual transmission that he has, but he also got the OmegaMax which he likes better for all its great features but the latter will not work on manual trans. Did I get that wrong?
Posted By: ers1121
Date Posted: June 11, 2004 at 10:58 AM
You have that right. I do have the Omega system, NIB got a deal that I could not turn down (free), Trying to make this work if possible. Draasch, I will try to call you this afternoon Ed ------------- Ed
Posted By: ers1121
Date Posted: June 17, 2004 at 6:01 PM
I was able to get the Omega and UltraStart to work together! It was simply a matter of using the lock/unlock of the UltraStart to disable the Omega. And it still worked with all of the safety measures built into the Ultrastart. Just one minor glitch, when you arm the system it chirps twice and once for disarming, the opposite of the way it should be. Other than that it works perfectly.
------------- Ed
