5wi
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33720
Printed Date: May 11, 2026 at 5:20 AM
Topic: 5wi
Posted By: Buriy
Subject: 5wi
Date Posted: June 11, 2004 at 10:08 PM
Lock Motor blue/red  5wi DKP or CTM, pink plug, pin 2
Unlock Motor BLACK/ red  5wi DKP or CTM, pink plug, pin 3
What means 5wi on this diagram? And how to use this connection with CompuSTAR 2WSSR?
Posted By: auex
Date Posted: June 11, 2004 at 10:28 PM
Uh, why would you need these wires? Do you know the significance of these wires?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Buriy
Date Posted: June 11, 2004 at 10:37 PM
I try to combine work of the original remote  and remote CompuSTAR 2WSSR
Posted By: draasch
Date Posted: June 11, 2004 at 11:15 PM
5wi means 5 wire system..............
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
