Parking light wire on 2000 Eclipse
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33731
Printed Date: May 11, 2026 at 8:38 AM
Topic: Parking light wire on 2000 Eclipse
Posted By: ajiuo
Subject: Parking light wire on 2000 Eclipse
Date Posted: June 12, 2004 at 8:58 AM
I hooked the alarm up and everything works great but I can not find the (+) parking light wire. The Wiring diagram for the car tells me it is a grn/wht or pnk/blk wire under the driver kick panel.
Does someone know if it’s on a particular connector?
Posted By: Velocity Motors
Date Posted: June 12, 2004 at 9:05 AM
The wire will be LOW in the driver's kick panel. When it says LOW that means it's under the carpet somewhere behind the panel under everything posted_image If you can gain access to one of the switches that illuminate, then use the light wire from there. It's the same thing.
