2003 Dodge Stratus SXT
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33760
Printed Date: May 11, 2026 at 9:13 PM
Topic: 2003 Dodge Stratus SXT
Posted By: Trancematic
Subject: 2003 Dodge Stratus SXT
Date Posted: June 12, 2004 at 6:53 PM
Hey everyone,
                        Im installing an alarm system for a 2003 dodge stratus sxt and need to find a wire diagram for the car.  I have the remote start aspect of the alarm already connected just need to find out where to find the other wires and colors.  I already checked the diagrams on this site and only found a 2001 stratus and it is very different compared to the 2003.  Please help and Thankyou ahead of time.
Posted By: draasch
Date Posted: June 12, 2004 at 7:00 PM
Make:   Dodge
Model: Stratus (Sedan)
Year:    2003
Alarm
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts DARK BLUE IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light RED / GREEN (-) DRIVERS DOOR SWITCH
Trunk Pin Switch TAN/BLACK (-) DRIVERS KICK PANEL
Parking Lamp BLACK / YELLOW (+) DRIVERS KICK PANEL
Power Lock WHITE/ LT.GREEN AT VEHICLE* #217
Power Unlock SINGLE WIRE SYSTEM FUSEBOX
#217 See Single Wire Resistor Door Lock Circuit. * WHITE/ LT.GREEN Door Lock Wire Must Recieve A (+) 12 Volts To Lock And A (+) 12 Volts Pulse Throu A 750 Ohm Resistor To Unlock.
Remote Start
Tach Signal BLACK/ GRAY AT IGNITION COIL #239
Ignition #2 GREEN/ RED IGNITION SWITCH HARNESS
Ignition #3 BLACK/ WHITE IGNITION SWITCH HARNESS (HVAC CONT)
Accessory BLACK/ ORANGE IGNITION SWITCH HARNESS (HVAC BLOWER)
Neutral Safety BLACK/ LT.BLUE (-) IN HARNESS TO TRANSMISSION
Brake Light WHITE/ TAN (+) AT FUSEBOX
Reverse Light VIOLET/BLACK (+) DRIVERS KICK PANEL
Rear Window Defrost
#239 See Immobilizer Bypass Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: June 12, 2004 at 7:41 PM
Thankyou So Much!
Posted By: draasch
Date Posted: June 12, 2004 at 7:55 PM
your welcome
Good Luck
David
Ace Security
813-376-9778
Tampa
Date Posted: June 12, 2004 at 11:33 PM
Hey I posted earlier on a 2003 dodge stratus alarm install.  Couple questions
Where can i find the factory alarm system at?
David posted a wire diagram install yet it doesnt match up with the wires in the car.  So i have been forced to try and find every wire.  So plz help
Posted By: Teamrf
Date Posted: June 12, 2004 at 11:59 PM
What ae you needing with the fac. alarm?
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Date Posted: June 13, 2004 at 12:09 AM
Door unlock/lock wire
Be able to disarm it.  Also the key has a chip in it so how do i bypass having the key in the ing. to auto-start vehicle? (without installing a key by the steering column)
Posted By: auex
Date Posted: June 13, 2004 at 2:01 AM
First, there isn't a factory alarm, it is the factory computer. Second read, this type of situation has been discussed for who knows how long. Chances are that you will still loose a key, whether you put it in the steering column, ghetto way, or in a key in the box type immobilizer is up to you.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
