Harada HCS-900
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3378
Printed Date: May 15, 2026 at 12:55 AM
Topic: Harada HCS-900
Posted By: MadBanchee
Subject: Harada HCS-900
Date Posted: September 06, 2002 at 7:36 AM
Has anybody heard of a Harada HCS-900 remote-start, keyless-entry alarm system???
I recently bought a used 2000 Dodge Durango with this thing installed in it and I am experiencing problems with it.  The vehicle has a factory alarm and keyless entry and it seems that the Harada (after market) alarm is arming itself a couple minitues after the vehicle is parked.  It seems that something may have been reset in the alarm system since this just recently started happening.
Does anyone have any information on this system???  I need a wire list for the I/O of the module and/or a manual that has programming information.  A wire list for the 2000 Dodge Durango would help too!  I have done some searching on the web and found that Harada has closed doors some time ago and can't seem to find any help/support out there!  So where do I turn?  THE12VOLT.COM of course!  As always the help is appreciated - Thanks.posted_image
Posted By: the12volt
Date Posted: September 06, 2002 at 11:03 AM
Hi MadBanchee, the only info I have on that unit is the sales literature, but I do have some numbers you can call that may be helpful:
U.S. 800-421-2753 or 800-522.7272
Canada: 416-247-0211
Here's what I have for a 2000 Durango: https://www.the12volt.com/installbay/detail.asp?info=alarm&year=2000&make=Dodge&model=Durango&ID=17614&type=Alarm
