Python 880XP
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33866
Printed Date: May 12, 2026 at 6:48 PM
Topic: Python 880XP
Posted By: misbell
Subject: Python 880XP
Date Posted: June 14, 2004 at 3:15 PM
I have a 487V transmitter that has lost communication with the vehicle. Does anyone know how to program this thing? I tried holding down the lock key with no success. I called Ultimate and he acted like it is a third world secret. Thanks in advance
Mike
Michael Jay Isbell
Posted By: hawkinstaller02
Date Posted: June 14, 2004 at 4:01 PM
Open the door (or ground the green wire)
Turn the key on
Press program button 8 times, then hit once more and hold it down this time
should chirp 8 times, while still holding the program button, hit the lock button on the remote, should chirp to confirm, do both remotes.
Let go of the program button
Most importantly, find a new shop if they would not help you with that
Did that work???????
-Installer-
Posted By: misbell
Date Posted: June 14, 2004 at 4:58 PM
Thanks, I will try that tonight and let you know. Once again, thanks for the help.
Mike
Engineer
KOCO Tv
OKC
Michael Jay Isbell
Posted By: misbell
Date Posted: June 14, 2004 at 5:01 PM
Sorry, I forgot something. This is my son's car. Where is the program button on the main system?
Mike
Michael Jay Isbell
Posted By: Scott35
Date Posted: June 14, 2004 at 5:05 PM
Those remotes have alot of problems, you may have to replace it.
Tacomacrew
Posted By: JWorm
Date Posted: June 14, 2004 at 8:07 PM
Mike
It varies from car to car. Your son should know the answer. Its a small black push button. If it was installed properly, it won't be out in the open.
As the poster said above, you will probably need to replace the 478 remote with a 479 series. They are much more reliable.
Posted By: nava94
Date Posted: June 14, 2004 at 11:11 PM
Once you find the valet button you have to open the door put the key in the cylinder to the on position then press the valet button 7-times then press and hold it once more. The siren will chirp and the led will flash 8-times. While holding the valet button press the arm/lock button on the transmitter the unit will chirp indicating succesful programming.If this does not work find an authorized DEI dealer so they could send the unit for repair. The unit you have is the first batch that they brought out and most of them had/have that problem with the remote not responding.
