BCM. 2000 Dodge Caravan
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34200
Printed Date: April 02, 2026 at 7:38 AM
Topic: BCM. 2000 Dodge Caravan
Posted By: Sven240sx
Subject: BCM. 2000 Dodge Caravan
Date Posted: June 19, 2004 at 3:40 PM
Hello all, new poster here.
I drive a 240SX and enjoy working on it every chance I get, but this post is about my mom's Dodge Caravan (2000). I agreed to install an alarm for her but I've never worked on these before and now I am stuck.
I need to find the lock/unlock wire. Searching through this site I know it's the white / dk. green wire coming from the Body Control Module. Only problem is I have no idea what a Body Control Module looks like or where it is located.
I've looked all over the place under the drivers dash including those 4 big screw in wire harnesses that plug in above the little row of fuses (which took forever).
Can anyone point me in the right direction?
Thanks in advance.
------------- Sven f/ Son240sx (mod)
1993 240SX FB
Date Posted: June 19, 2004 at 3:54 PM
just found this thread:
https://www.the12volt.com/installbay/forum_posts.asp?tid=5337&KW=BCM
I will have a look again now and see if I can see it!
1993 240SX FB
Posted By: auex
Date Posted: June 19, 2004 at 7:11 PM
Look on the firewall under the driver's side underdash. It will be the box that has about 4 plugs coming out of it, it is mounted to the firewall.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
