2003 Chevy Alarm Install Wiring Diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34561
Printed Date: March 28, 2026 at 8:29 PM
Topic: 2003 Chevy Alarm Install Wiring Diagram
Posted By: mme6342
Subject: 2003 Chevy Alarm Install Wiring Diagram
Date Posted: June 25, 2004 at 12:45 PM
I need a wiring diagram for the install of a Prestige APS-875a Alarm/Remote starter into a 2003 Chevy Express 1500 van. Any help would be much appreciated. THANKS
Posted By: jfk51502003
Date Posted: June 25, 2004 at 12:47 PM
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / EXPRESS VAN / 2003 / Security[PRINT THIS PAGE]
| 12volts | RED / black (x2) | + | ignition harness | | Starter | yellow | + | ignition harness | | Ignition | pink | + | ignition harness | | Power Lock | lt. blue | - | pin B5, lt blue plug at BCM | | Notes: The BCM (Body Control Module) is under the passenger side dash, behind the knee bolster. | | Power Unlock | white | - | pin B10, lt blue plug at BCM | | Notes: The BCM (Body Control Module) is under the passenger side dash, behind the knee bolster. | | Lock Motor | gray | 5wi | driver kick, door harness | | Unlock Motor | tan | 5wi | driver kick, door harness | | Disarm Defeat | tan | 5wi | fuse box under driver seat | | Parking Lights+ | brown | + | fuse box under driver seat | | Parking Lights- | BROWN / white | - | pin B2, brown plug at BCM | | Notes: The BCM (Body Control Module) is under the passenger side dash, behind the knee bolster. | | Hazards | white | - | pin A5, gray plug at BCM | | Notes: The BCM (Body Control Module) is under the passenger side dash, behind the knee bolster. | | Turn Signal(L) | lt. blue/white | + | steering column | | Turn Signal(R) | dk. blue/white | + | steering column | | Door Trigger | see notes | - | lt. blue plug at BCM | Notes: The driver door trigger is tan in pin B4, the front passenger and rear cargo door trigger is lt. green in pin A5, and the rear doors or sliding doors trigger is yellow/black in pin A10. Use all three wires and diode isolate each.
The BCM (Body Control Module) is under the passenger side dash, behind the knee bolster. | | Dome Supervision | gray/black or dk. blue/wht | + | pin E, black plug at BCM | | Notes: The BCM (Body Control Module) is under the passenger side dash, behind the knee bolster. | | Trunk/Hatch Pin | common with door trigger | | | | Hood Pin | N/A | | | | Trunk/Hatch Release | N/A | | | | Power Sliding Door | N/A | | | | Factory Alarm Arm | N/A | | | | Factory Alarm Disarm | N/A | | | | Disarm No Unlock | N/A | | | | Tachometer | white or purple | ac | pin 26, green plug at PCM | Notes: It is white on the 4.3L, and purple on the 4.8L, 5.3L, and 6.0L.
The PCM (Powertrain Control Module) is on the driver side fender. | | Horn Trigger | tan | - | pin B9, gray plug at BCM | | Notes: The BCM (Body Control Module) is under the passenger side dash, behind the knee bolster. | | Memory Seat 1 | N/A | | | | Memory Seat 2 | N/A | | | | Memory Seat 3 | N/A | | |
| Immobilizer Bypass Module: | Required: Yes | Type: Passlock 2 | Part #: 555L or 555T | | Notes: The Passlock 2 wire colors are yellow, tan, and ORANGE / white (not used). |
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter. Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information. |
Posted By: mme6342
Date Posted: June 25, 2004 at 1:26 PM
Man that was quick! thank you, will be installing it this weekend
