Need wiring diagram Please Help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34636
Printed Date: March 28, 2026 at 1:04 AM
Topic: Need wiring diagram Please Help
Posted By: sefrm0
Subject: Need wiring diagram Please Help
Date Posted: June 26, 2004 at 4:48 PM
I just bought a 2003 buick century and have an alarm to install in it. I cannot find the wiring diagram for this vehicle every where that I have search for. Our database only gives vehicle information up to the year 2000. If anyone can help out with the information needed please let me know. Thanks
------------- Gage
Posted By: jfk51502003
Date Posted: June 26, 2004 at 5:08 PM
DIRECTWIRE™ WIRING INFORMATION - BUICK / CENTURY / 2003 / Security[PRINT THIS PAGE]
| 12volts | red | + | ignition harness | | Starter | yellow | + | ignition harness | | Ignition | pink | + | ignition harness | | Power Lock | RED / black | - | driver kick or BCM | | Notes: The BCM (Body Control Module) is to the left of the steering column. | | Power Unlock | ORANGE / black | - | driver kick or BCM | | Notes: The BCM (Body Control Module) is to the left of the steering column. | | Lock Motor | gray | 5wi | driver kick, door harness | | Unlock Motor | tan | 5wi | driver kick, door harness | | Disarm Defeat | tan | 5wi | pass. kick, door harness | | Parking Lights+ | lt. blue | + | headlight switch | | Notes: Larger of the two at the light switch. Can also find BROWN / white in the passenger kick panel in the harness to the rear. | | Parking Lights- | | | | | Hazards | | | | | Turn Signal(L) | | | | | Turn Signal(R) | | | | | Door Trigger | dk. blue/white | - | driver kick or BCM | | Notes: The BCM (Body Control Module) is to the left of the steering column. | | Dome Supervision | use door trigger | | | | Trunk/Hatch Pin | ORANGE / black | - | light in trunk or BCM | | Notes: The BCM (Body Control Module) is to the left of the steering column. | | Hood Pin | | | | | Trunk/Hatch Release | brown | - | BCM | | Notes: The BCM (Body Control Module) is to the left of the steering column. | | Power Sliding Door | N/A | | | | Factory Alarm Arm | | | | | Factory Alarm Disarm | | | | | Disarm No Unlock | | | | | Tachometer | PURPLE / white or white | ac | ignition control module | | Horn Trigger | black | - | steering column | | Memory Seat 1 | | | | | Memory Seat 2 | | | | | Memory Seat 3 | | | |
| Immobilizer Bypass Module: | Required: Yes | Type: VATS | Part #: 652T resistor pack | | Notes: See DirectFax document 1049 for interface information. |
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter. Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information. |
