Alarm HELP!! for 99 Galant
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34766
Printed Date: May 22, 2026 at 4:29 AM
Topic: Alarm HELP!! for 99 Galant
Posted By: dc4life1981
Subject: Alarm HELP!! for 99 Galant
Date Posted: June 28, 2004 at 9:49 PM
I had an alarm installed on my 99 Mitsubishi Galant about 2 years ago.  Now it won't alarm or disarm.  If I use the remote it will not do anything, it makes a noise like it wants to work.  The lights don't flash and now I can't even lock the doors without the key in the ignition.  Is this problem because of the car alarm?  This alarm is useless now, but I want to know if it is something simple that can be fixed.  I know its getting some type of power because it tries to work.  Every now and then it will try to chirp but then it stops.  And to make matters worse I tried to take it back to the installer and they are not even in business anymore!!!  Great. Any type of help will work.  Thank you
Dawn C.
Posted By: swamprat323
Date Posted: June 28, 2004 at 10:56 PM
What kind of alarm? When you say makes a noise like it wants to work can you give more detail? You may have a power/ground problem. How much do you knwo about alarms, if some going to have to find the brain and see the power/ground wires.
