Insulating soldered wires
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34935
Printed Date: April 03, 2026 at 2:18 AM
Topic: Insulating soldered wires
Posted By: spokman
Subject: Insulating soldered wires
Date Posted: July 01, 2004 at 11:37 PM
How do you all insulated wires when you solder them in mid harness? I would seem that tape is the only way. I'm not a huge fan of tape but is there another option? Thanks!
Posted By: auex
Date Posted: July 01, 2004 at 11:40 PM
Yeah, electrical tape.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: cool_greg
Date Posted: July 02, 2004 at 12:17 AM
heat shrink
------------- Just a Guy, Wiring up those Vehicals
Gool_Greg
Posted By: auex
Date Posted: July 02, 2004 at 12:27 AM
Can't heat shrink a t type connetion unless you cut the wire. Good electrical tape works just fine, I install in AZ where it is well over 100 for more then the summer and tape works fine.
Posted By: jugga-nemo
Date Posted: July 02, 2004 at 10:17 AM
I usually just cut the wire that I"m tapping into and solder all three ends together (the cut wire and the wire to splice with). Then just heat shrink. It may not be the best way, but I've never had a problem with it.
------------- 5.25" Components & 5x7 Coax Kappas w/Power Acoustik OV4-800
KAC 7252 powering 2 D3 8" Diamonds
KDC-MP728, KGC-4042A
Posted By: spokman
Date Posted: July 02, 2004 at 12:03 PM
That is a great idea! Odd how sometimes your brain doesn't think of the simplest things. Now what type of heat shrink do you guys use? Where I work we use a lot of different types. My favorite is a black dual wall, high temp heat shrink. Stuff sets like a rock. Not sure if auto wires can take the heat to shrink it though.
Date Posted: July 02, 2004 at 12:38 PM
I didn't know that there was different kinds, but it makes sence for different applications. I just buy the stuff they sell at Home Depot or Lowes in the electrical dept. It just shrinks down with a heat gun (not sure of the temp at which it will shrink as mine doesn't adjust) or a lighter.
Posted By: NINsane18
Date Posted: July 02, 2004 at 7:41 PM
3m 33+ is the best tape I have used so far.
------------- Tim-May!
