2004 caddy deville/ pk3?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35064
Printed Date: April 05, 2026 at 4:25 PM
Topic: 2004 caddy deville/ pk3?
Posted By: hafr
Subject: 2004 caddy deville/ pk3?
Date Posted: July 05, 2004 at 11:17 AM
what kind of data buss does the new deville have. Can you data buss the doorlocks or do you have to go into the  drivers door?
 any info would be greatly appreciated
thanks
Rich Hawthorne
Hands-Free installations
"don't talk with your hands full"
516-no-hands
Posted By: sparkie
Date Posted: July 05, 2004 at 3:31 PM
The car uses Passkey III (Transponder). There are many modules available to integrate with it. Some will also control the power locks and factory alarm. You could also run wires into the door for lock, unlock, disarm and arm. To arm the alarm you must pulse the doorpin just slightly before the lock wire. The lock/unlock wires are at the switch in the door and the disarm (light green) and the doorpin (tan) are in a plug at the driver's door module behind the door trim panel. I would recommend an all in one module for ease of install.
sparky
Posted By: kgerry
Date Posted: July 05, 2004 at 4:59 PM
the data model you are asking about is a 456a from DEI.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: hafr
Date Posted: July 05, 2004 at 6:52 PM
thanks for the info. I data bussed this car on thursday with a crimestopper gmu-7 and got the doorlocks. then i used a key in a box for the ignition. The car locked up 200 miles from home. do you think maybe the car saw two keys at the same time? i know on fords(navigator,focus) if the key is in the ignition and you remote start it it sees 2 keys and lock out, just for that one try.
thanks
Rich Hawthorne
516-no-hands
