Schematics Request: 1993 BMW 325is
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35094
Printed Date: April 06, 2026 at 4:46 PM
Topic: Schematics Request: 1993 BMW 325is
Posted By: sigma_x
Subject: Schematics Request: 1993 BMW 325is
Date Posted: July 05, 2004 at 9:40 PM
Hi, could someone please post the DEI wireing schematic for a 93 325is BMW? Thanks!
1993 BMW 325is
Posted By: sigma_x
Date Posted: July 05, 2004 at 9:58 PM
Which schematic is the right one?
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1993&make=BMW&model=325&ID=13206&type=Alarm
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1993&make=BMW&model=325&ID=13301&type=Alarm
Thanks!
1993 BMW 325is
Posted By: sigma_x
Date Posted: July 06, 2004 at 12:36 PM
Come on, somone?
1993 BMW 325is
Posted By: datrick
Date Posted: July 06, 2004 at 12:55 PM
BMW / 3 SERIES / 1993 / Remote Start
[PRINT THIS PAGE]
12volts RED / wht or red   +  ignition harness
Starter blk/yel or black   +  ignition harness
Second Starter
Ignition green   +  ignition harness
Second Ignition pur/wht or purple   +  ignition harness
Third Ignition
Accessory
Second Accessory
Keysense
Power Lock WHITE/ red   +  factory alarm plug
Notes: The alarm plug is a black 12 pin plug located just behind the glove box. It is mounted with the pins facing you atop a vent just to the left of the body computer. Other wires at the alarm plug are: 12V- RED / white; Accessory- PURPLE / white; Siren- BLACK/ blue; Ground- BROWN / orange. Do not use the power sources at the alarm plug to operate high-current devices. The other side of the siren wire is mounted in a 2 pin plug at the passenger rear corner of the engine compartment. The other wire in the plug is a brown ground wire. DEI recommends attaching the siren at this point.
Power Unlock blue/red   +  factory alarm plug
Lock Motor
Unlock Motor
Parking Lights+ gry/pur, gry/yel    headlight switch
Notes: These wires are the separate left and right parking light wires. Use both wires and isolate each.
Parking Lights- blue/green (hazards)    factory alarm plug
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger    -  factory alarm plug
Notes: Door triggers are BROWN / gray for the drivers front door, BROWN / blue for the passenger front door, and BROWN / black for the rear doors (if equipped). Use all three wires and diode isolate each.
Dome Supervision comes on with unlock
Trunk/Hatch Pin BROWN / white   -  factory alarm plug
Hood Pin PURPLE / green   -
Notes: The hood pin wire can be found at the radio harness or at the hood pin switch.
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Notes: If equipped with a factory alarm, the alarm will be plugged into the factory alarm plug. The only way to arm and disarm the factory alarm is with the factory remote. If your planning on using the 8360 pre-wired alarm harness the factory alarm must absent or removed.
Disarm No Unlock
Tachometer black  AC  instrument cluster
Notes: The wire is located in a white connector behind the instrument cluster. Do not unplug the white connector with the ignition on or turn the ignition on with the plug disconnected.
Wait to start
Brake Wire blu/red or grn/red   +  at brake pedal switch
Parking Brake
Horn Trigger brn/red or brn/yel   -  steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
posted_image
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
Posted By: sigma_x
Date Posted: July 06, 2004 at 1:28 PM
1993 BMW 325is
