Compustar LED too bright
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35215
Printed Date: April 08, 2026 at 8:06 PM
Topic: Compustar LED too bright
Posted By: jepherz
Subject: Compustar LED too bright
Date Posted: July 07, 2004 at 11:30 PM
I just got my new compustar installed. It came with that bright blue LED. Sure, it looks fine during the day, but when it's dark out, it's like a freakin' blue light special in my car. I am affraid that this is, in turn, just going to attract people to come kick my car. Any of you guys have any advice or have you done anything about this problem? Is it possible to wire in a small relay to tone it down and if so, how many ohms?
------------- "Screw nitrous, I'd rather be blown."
Posted By: sroth140
Date Posted: July 07, 2004 at 11:36 PM
well not relay, resistor. if you want you can try 220 ohms. if it has a plastic diffuser cover, see if you can pull it off and that will leave just the tiny LED tip. youll have to make a new mounting hole tho. the diffuser cover spreads the LED light out so you dont have to look at it straight on so see it brightly.
------------- MECP certified installer
