Window wiring help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35297
Printed Date: April 03, 2026 at 3:54 PM
Topic: Window wiring help
Posted By: nolimit
Subject: Window wiring help
Date Posted: July 09, 2004 at 12:41 PM
I own a 2003 mitsubishi galant with a prestige aps 995c installed and remote start. I want to wire the module to allow my windows to roll up/down while car is turned off. Does anyone have an idea of how to do this. My instructions do not show me how to do this so help would be appreciated.
Posted By: profuse007
Date Posted: July 09, 2004 at 12:56 PM
you can have the unit(window module) be active when you arm ur alarm. that wire from the alarm is called "ground when armed"- orange on primary harness(20pin).
that will get you started.
Houston,TX
Posted By: TheBayArea
Date Posted: July 10, 2004 at 4:03 AM
what window module do you have? if you dont have one, go get the 530T by dei, then come back. the 530t will allow you to roll your windows both up and down. 529t will let you roll your windows in 1 direction, so make sure you get the 530T
