compustar remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35557
Printed Date: April 07, 2026 at 11:27 AM
Topic: compustar remote start
Posted By: jepherz
Subject: compustar remote start
Date Posted: July 13, 2004 at 10:05 PM
For everyone reading this, I have a 93 mitsubishi eclipse and I am not able to get the remote start to work. I have all of the wires hooked up (parking brake, foot brake, etc.) and am still having a problem. My car has automatic seat belts, and they retract, so I know the ignition is turning on. The one part I think may be causing a problem is the fact that on my key harness, there are two wires that should be turned on with the ignition. I hooked one of these wires up to the ignition coming off the alarm, and the other up to the ignition relay. The reason I am questioning this is because the blue-black wire for ignition is not shown to be on during start(crank) on my wiring diagram.
If this could be the cause of my problem, or if you guys have any other ideas, let me know.
Thanks,
------------- "Screw nitrous, I'd rather be blown."
Posted By: jepherz
Date Posted: July 13, 2004 at 10:33 PM
BTW, I forgot to mention everything is coming on, except the starter never cranks.
