alarm for 1998 Malibu
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35579
Printed Date: April 07, 2026 at 11:27 AM
Topic: alarm for 1998 Malibu
Posted By: 2blk72
Subject: alarm for 1998 Malibu
Date Posted: July 14, 2004 at 11:24 AM
OK i want install an alarm for a Malibu, I have bought 4 diodes and I have also bought 2 relays I think that I need them for the doors I think I might one for the trunk also what else will I need to by to make this project work for me? I also need help on the diodes do I solder them to my door trigger wires? I just really need any help that can be given to me thanks alot. I have a K-9 Mundial-2 alarm.
Posted By: Velocity Motors
Date Posted: July 14, 2004 at 11:54 AM
The lt. GREEN/ black is located in the drivers kick and catches only the drivers door. The lt. blue is located in the harness coming from the drivers running board going under the drivers seat and it catches all other doors. Use both door trigger wires and diode isolate each. according to the diagram with the band facing the door trigger wires ( away from the alarm brain )
Posted By: another-kelly
Date Posted: July 14, 2004 at 7:52 PM
https://www.the12volt.com/relays/relays.asp
for the trunk release (assuming you already have power trunk pop); #86 & #87 = +12v , #85 = neg. trunk output from alarm, #30 = black wire at the trunk release switch, #87a = not used
