95 Explorer Door Triggers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35614
Printed Date: April 06, 2026 at 9:16 PM
Topic: 95 Explorer Door Triggers
Posted By: spokman
Subject: 95 Explorer Door Triggers
Date Posted: July 14, 2004 at 11:19 PM
The diagrams that you can get here and from alarm companies are incorrect for my Explorer. Don't know if it's because it is a limited or not? The charts say the door trigger should be the BLACK/ blue wire. That is the courtesy lamp circuit. There are four seperate door trigger wires that go into the GEM module. Then one wire goes to the RAP(factory alarm). Think I found the one wire but it doesn't seem to switch polarity or do much. Light blue/white wire. I know I could tap all four door trigger wires but I'm wondering if there is an easier way?
Thanks!
Posted By: draasch
Date Posted: July 15, 2004 at 3:04 AM
Dome Light TAN / YELLOW(-) AT GEM MODULE HIGH IN DRIVER DASH *
* BLACK/ L BLUE (+) At Dimmer Module Located On Left Hand Side Of Steering Column Can Also Be Used
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: spokman
Date Posted: July 15, 2004 at 8:53 AM
But I'm pretty sure the dome light will come on when you lock the doors sometimes. I know I've locked it and seen the dome light on and wondered if it was going to turn off. Maybe that courtesy light circuit is only on when the doors are open? Need to stare at my wiring diagrams some more..!
