door poppers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35818
Printed Date: April 06, 2026 at 2:13 PM
Topic: door poppers
Posted By: subzero
Subject: door poppers
Date Posted: July 19, 2004 at 7:47 AM
Could any body please tell me where i can get good door poppers as i have got a guy who wants me to put them on his car cause the silly bugger has removed the lock and handleTA!
the iceman
Posted By: Teamrf
Date Posted: July 19, 2004 at 7:55 AM
Try Ebay..they may have something on there.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: lspker
Date Posted: July 19, 2004 at 8:48 PM
You can use a trunk seleniod or in a pinch a power doorlock actuator.  You can hang the door on the hinges so that it wants to open it self.  Any local car audio/alarmshop should have the parts for you.  The poppers are just a spring loaded shafts (just need something to keep the spring straight)
Posted By: swamprat323
Date Posted: July 19, 2004 at 10:35 PM
Tere is a link on the 12volt site over to the left and down. here it is also.
Poppers and things.
Posted By: Thack79
Date Posted: July 20, 2004 at 6:21 AM
Dont get them from Summitt. The solinoids are terrible.
Posted By: subzero
Date Posted: July 21, 2004 at 4:44 PM
thanks to all the replies us scots are starting to get crazywith these things.
i also found out if you tighten the door in against the door seals this could be enough force to spring out the door any replies would be greatful.
the iceman
Posted By: tanz2004
Date Posted: July 21, 2004 at 6:52 PM
My Door Opens with a 1 1/2 to 2 in. stiff spring and a cable type trunk release.  However in case some one has not already told you! Don't forget about the backup plan. Batteries die and remotes lost. Don't want to have no way in or out. I have an area in my wheel well that I can access with a key to gain access to Manual backup. However I have been installing Alarms and thing for almost 20 years. I had a Chevy Luv that I locked my self out of once 12 years ago, I learned the hard way.
Good Luck!
TanZ2004
Washington State
