How’d I know when to use a relay?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35833
Printed Date: April 06, 2026 at 4:06 PM
Topic: How’d I know when to use a relay?
Posted By: vbel
Subject: How’d I know when to use a relay?
Date Posted: July 19, 2004 at 1:44 PM
I want to install a Compustar 2wss-as alarm into my 2000 prelude. How do I determine that I have to use a relay to make a certain function work? What will happen if I don't use a relay where I'm suppose to? Will it damage something or just won't work until I connect in the relay?
Posted By: Velocity Motors
Date Posted: July 19, 2004 at 1:52 PM
Relays are used to trigger a device that requires more current than the CPU is capable of outputting. Relays are used in lots of different applications for alarm or remote start situations. If you tell us what you are trying to do with the Compstar we can tell you if it needs a relay or not.
Posted By: vbel
Date Posted: July 19, 2004 at 2:10 PM
I read the section on relays on this site, so I know the basics. But it still doesn't tell me how to check for or how to know for sure that this and this will nead a relay in order to do this and this for the function to work.
What I'm trying to do is intall the compustar alarm, which also has a remote start. I need to know basically all the connections (if I need a relay or not) I have to make for this thing to work. This is just what I could remember from the top of my head:
- 12v constant
- ignition
- accessory
- status output
- door triggers
- door lock
- door unlock
- hood pin switch
- trunk pin switch
- trunk trigger
- trunk release
- parking lights output
- tachometer input
- siren output
- horn output
- brake
- parking brake
Posted By: loudsh*t
Date Posted: July 19, 2004 at 6:00 PM
12voltswhite + ignition harness
StarterBLACK/ white + ignition harness
Second Starter
IgnitionBLACK / YELLOW + ignition harness
Second Ignition
Third Ignition
Accessoryyellow + ignition harness
Second Accessory
Keysense
Power LockBLACK/ white -
Notes: located in the passengers kick at the multiplex control unit in a blue 14 pin connector.
Power Unlockblue/orange -
Lock MotorWHITE/ red bottom of fuse box
Unlock Motorlt.GREEN/ red bottom of fuse box
Parking Lights+RED / black
Notes: located in a white plug just behind the cruise control switch.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door TriggerWHITE/ black - bottom of fuse box
Dome Supervisioncomes on with unlock
Trunk/Hatch Pinorange -
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlockblue - in drivers door
Tachometerblue cluster or test connector
Notes: test connector is located to the front of the right strut tower.
Wait to start
Brake WireWHITE/ black + at brake switch
Parking Brake
Horn Triggerblu/rd or lt grn/blu - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
posted_image
Immobilizer Bypass Module:Required: YesType: TransponderPart #: 555D, 556U, or 555U
Best Buy Installer
Posted By: tanz2004
Date Posted: July 19, 2004 at 6:45 PM
vbel]< wrote:
r>What I'm trying to do is intall the compustar alarm, which also has a remote start. I need to know basically all the connections (if I need a relay or not) I have to make for this thing to work. This is just what I could remember from the top of my head:
Ok here is some advise that I think might be needed. One "Automotive Alarms are Not Toys" Two "When in Doubt sub it out" In other words you can really mess up your car if you don't know how to install an alarm. One with Remote Start I would not even try and installing one without knowing how to do a Basic alarm first. Now for your question.
Parking light Flash needs a relay if not already onboard, Door Locks need relay At least 2 some times more. Dome light Supervision needs a relay, Starter Kill needs a relay. and the list goes on and on. So without the training needed to install this alarm Sub it out to a Pro.
TanZ2004
Washington State
Posted By: sroth140
Date Posted: July 20, 2004 at 2:33 AM
drivers door priority with 5wi locks :o , theres a couple relays.  extra accy/ign wires, often parking lights depending on the brain.  trunk pop, horn honk, rear defogger, neons, motorized doors, wipers, illuminated path (head lights), adding lock actuators, adding more sirens, motorized amp racks, ect....
basically, the brain sends out low current (-) triggers to activate relays to do heavier current jobs.  such as whats listed above and then some.  relays can be used to make/brake/isolate different circuits.
MECP certified installer
