Connecting Multiple Modules
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35865
Printed Date: April 07, 2026 at 1:26 AM
Topic: Connecting Multiple Modules
Posted By: Tengoku
Subject: Connecting Multiple Modules
Date Posted: July 19, 2004 at 10:33 PM
The alarm unit only has one input for a 3 wire connection which is used by an impact sensor... however, I bought a motion detector and would like to install this as well as the impact sensor..
If I wanted to do this... how would I go about doing this? would I Just splice into the 3 wires connected into the alarm unit and connnected the appropriate wires? can I do this with multiple modules??
Posted By: JWorm
Date Posted: July 20, 2004 at 12:01 AM
Get power and ground from a different source. You can use the same trigger wire, but you will need to diode isolate the two wires from each other. Read the section here on the top left about diodes.
